- Aug 6, 2007
- 452
Not including masonry heaters and the like, what is the most efficient wood burning stove on the market today? I'm must curious.
Thanks!
Thanks!
Webmaster said:No such thing.
We could only say this if each and every stove were tested for actual efficiency. They are not. Most of the figures given are "default" efficiency standards. Also, EPA tests are done with pine 2x4 and 4x4.
Based on all this and more...I would say the most efficient stove is the one burned correctly and that has at least 8 feet of single wall stovepipe exposed in the house!
Catalytic test more efficiently in many cases, but might lose their advantage as the cat ages....and so on, and so on.
Webmaster said:Based on all this and more...I would say the most efficient stove is the one burned correctly and that has at least 8 feet of single wall stovepipe exposed in the house!.
I think a properly built masonry heater can probably meet or beat many stoves
Webmaster said:Yeah, a lot of modern stoves put vast amounts of heat up the stack when burned hot. It is tough to design enough exchange into a little stove that must fit dimension requirements. I think some setups would see 10-15% increase from some exposed stack....
Hanko said:Geez Im surprised someone didnt chime in saying the stove they owned was the most efficient. My vote Big MF barrel stove
Doing The Dixie Eyed Hustle said:I think a properly built masonry heater can probably meet or beat many stoves
On the style of a "Russian Fireplace", or something else???
ControlFreak said:Webmaster said:No such thing.
Just in case anybody is curious:
I spoke in detail with one of the EPA test lab reps at last years HPB Expo. I asked how they measure the BTU output and efficiency rating for a stove. He said that they don't directly measure the heat output of a stove, but rather, they calculate it. Here's how it goes (from what I recall):
1. They start with a load of wood that is precisely weighed.
2. From this load of wood, they calculate the total BTU content in the wood.
3. As they burn the fire, they continuously monitor the temperature of the exhaust gases, and the flow rate.
4. Knowing the exhaust gas temperature and the rate of flow, they can calculate the BTU's going up the chimney.
5. Whatever heat does not go up the chimney, they conclude is being extracted by the stove.
6. Heat output is total wood BTU content - BTU's going up the chimney.
6. From this, they can calculate the "efficiency" of the stove.
I didn't ask if they take into account the level of unburned gases since smoke is energy going up the chimney that doesn't produce any heat, and could lead to an artifically high efficiency.
Interesting stuff...
Dan
Dan
Todd said:Isn't Juca out of business? How the heck can you get a clean efficient burn out of that large fire box? Does it have some kind of secondary burn system?
Hogwildz said:The Juca is basically a Heatform like firebox, with heat exchange tubes at the top.
Think fireplace grate heater, but at the top of the fire box.
Much like a fireplace, alot of heat is going up & out.
Not knocking it, I was considering one a few years back.
If you can get a secondary baffle in there, you would then realize the heat your losing, or with secondary, losing much less of.
