Trying to figure out what’s going on here. This 5 yr old splitter just started leaking small amount of oil in the 2 spots in the pics. Last use was in Maine about 2.5 months ago and then it got trailered back to CT where it’s sat in the garage since. I recently moved the splitter a few feet so I know the oil spots on the garage floor are new. I put a piece of cardboard down to see if it would continue dripping and a couple days later I saw that it had. I checked the oil level and that is good/oil clean.
I should Jack the thing up and take a better look underneath. I took a couple pics of the underneath area where the 2 leaks are occurring. Was curious if you all had thoughts on what this could be.
![25 ton DHT splitter oil leak 25 ton DHT splitter oil leak](https://www.hearth.com/talk/data/attachments/317/317661-0fcde79f2cb77175ce0b1e3c47918ed2.jpg)
![25 ton DHT splitter oil leak 25 ton DHT splitter oil leak](https://www.hearth.com/talk/data/attachments/317/317658-9adc93b0baaf9959c506c9736d8a69db.jpg)
![25 ton DHT splitter oil leak 25 ton DHT splitter oil leak](https://www.hearth.com/talk/data/attachments/317/317659-72e55de98c217e6c7e0b15e3b29c4a30.jpg)
![25 ton DHT splitter oil leak 25 ton DHT splitter oil leak](https://www.hearth.com/talk/data/attachments/317/317660-8c1cca9b95470fdb0960f97732e89e03.jpg)
