Stove: 25-PDVC with Thermostat hook-up
Vent pipe: Simpson, Pipe adapter into Tee, 1' pipe, 3' pipe, elbow, 1' pipe through wall thimble, 1' pipe to cap.
OAK: Supplied OAK exciting through the wall about 1 1/2' above stove connection (Had to be sure to get above the snow line).
Had the stove set on 9 9. Burned for about 2 hours then went into low burn (assume 1 9) for about 45 minutes. Then went to high burn (9 9) for about 1 1/2 hours. I now have it on 5 5 (And using the oil furnace) as the blower was getting annoying. It seems the vent pipe is always hotter then the stove is. Even on 9 9 I can still touch the stove just above the blower vent. Wouldn't want to leave my hand there to long but a few seconds is OK. The vent pipe on the other hand, I can touch this just under the elbow and would not want to leave my hand there for even a second. Even outside the pipe is hot, though it cools off before the vent cap (It was only 15 outside when I checked it).
I do not have anyway to get any accurate measurements, but did not expect the vent pipe to be quite this hot. Especially since it only has a clearance requirement of 3", and the stove has a 6" requirement.
Just wondering if this is normal. If this is how it is going to run, I may need to find a way to get this heat off the pipe and into the room.
