25 PDV "E" code
When was the last time the stove was disassembled and cleaned
E1 is a blocked flue . Your stove is chocked full of ash or blocked
in some other way . When was the last time the chimney was cleaned ?
Also poss vacuum switch ,hose or ash in nipple
Welcome to the forum
Chimney was cleaned about a month ago
Stove was cleaned and top auger pulled and cleaned. Top auger keeps getting stuck with pellets.
Found this problem after putting auger back together.
Jumped the vacuum switch and sure enough stove stays on.
Auger still jams after about 30 minutes....ongoing problem.
What is the exhaust configuration? Have you checked the vacuum hose for cracks (both)? Have you cleaned the port in the firebox that the hose is attached too? Cleaned down behind the impingement plate? Cleaned the combustion blower and chamber?
