220v fan limit switch
werneb01
1
Northern WI
Hello,
I have a Northern Leader forced air wood furnace in the basement. The blower went out and I have a good blower off of a gas fired forced air furnace I would like to replace it with. However, the replacement is a 220 volt motor. Do they make a 220v fan limit switch? Or is there a way to use a 110v switch with a relay or something?
Thanks,
Brad
werneb01 said:
Hello,
Thanks,
Brad
I would be surprised if the 220V motor is not re-wire-able for 120 if you read the insides of the cover plate where the power goes in. If it is not OK for 120, you want a 120 volt coil, DPDT or DPST contact relay so that you can switch both "legs" of the 220. If you cannot take it from there, I don't want to be liable if you blow yourself up.
Another consideration is how close to the wood burner do you have 220V service? Do you really want to mess with adding a 220V circuit just for this fan if one is not readily available?
You could always check out places like grainger.com for a transformer but I'm betting the cost would be more than the fan is worth.
