2.beans said:steam man what size storage tank do you use and what have you been able to get your tank temp up to?
steam man said:My tank just hit 120 deg at 2:00 PM. Collector temp is 133 deg.
Below is my installation.
2.beans said:what are you doing up at 3AM? ive built some long thremowells but its easyer to show in a picture than trying to describe it. ill try to post a picture this week of the thermo well.if your temp sensor is on the outside i bet your inside temps are higher. im wondering what i would need to heat up 1000 gallons for useable hot water. i can shut off one tank so id only have 500 gallons though, which may be easyer. keep up the posts, thanks
steam man said:You need to find a way to dump the heat in summer as the fluid will boil and pressurize. Alternately you need to come up with a way of covering the panels when you dont need the heat.
Mike
Hansson said:steam man said:You need to find a way to dump the heat in summer as the fluid will boil and pressurize. Alternately you need to come up with a way of covering the panels when you dont need the heat.
Mike
I know that people here are building systems so the can reach stagnation.
I have try to find some info in English
http://www.aee-intec.at/0uploads/dateien48.pdf
