Is there a chart or info about moving BTU's and pipe size?
To move the btu's does a variable speed pump - say pump to storage tank from boiler is variable....say it speeds up with increase in heat ....would that make a real difference in heat transfer...enough to cover cost?
If I set up a used propane tank for pressure storage from boiler whats a good way to install the copper loops for the house heat inside the tank?
I know pump sizing matters - I know pipe size matters - but how?
Thanks for helping
Thanks for helping
