![2 KW or bust 2 KW or bust](https://www.hearth.com/talk/data/attachments/107/107443-6104f8331a17b39f635e0378872a1c17.jpg)
I don't claim that this is the neatest electrical install, just complex. There are three separate systems that were installed at various times in a tight space. Someone with a new system would only need the Silver box on the right mounted near their electrical panel, and folks who use microinverters wouldn't even need the central inverter box (albeit at a higher system cost). Adding the gutter under the panels allowed me to cut out a lot of extra wire runs. The tan inverter is 11 years old and was the original install. The only diagnostics is a blinking red led and it doesn't indicate output. I added the ammeter and hobbs meter in the small gray box in the corner so I could keep track of its output (5.7 KW over 11 years) Its only a 660 watt system. All of three inverters feed the subpanel on the left and then it feeds though an outdoor disconnect to a 40 amp breaker on the main panel. I do really dislike the required warning labels, they really mar up the looks of things. I would like engraved plaques but they would be costly and realistically not many folks care what the power end of a PV system look looks like. There is an attempt by some locals to get enough PV systems together that it makes sense to sell SRECs, if that happens I will have to install a new export power meter off the external disconnect. In order to do this we need to pay someone to drive 2 to 3 hours one way to record the meter outputs plus pay someone to broker them so its questionable if its worth it.
Its tough to get a picture of the new system due to it being on the second floor and at a shallow angle. For reference the original system hanging off the front of the house is currently set at 45 degrees. The SHW panels are set at 60 degrees to optimize spring and fall and cut back on summer overheating. It works but they do stick out. The SHW system is the oldest install and has been humming along for about 14 years. Given Heat Pump hot water heaters and low cost panels, I would not install SHW again and would just install more panels. Its hard to see but to the left of the new panels is a roof mounted combiner box. It has a great flashing arrangement and makes a nice roof pass through that isn't going to leak. Installed on it is a Midnight Solar surge arrestor. This in theory will pass any high voltages surges down to the ground system. I also have one on the main panel. There are no guarantees if I get a direct lightning hit but its the best thing they make currently.
Tom in Maine from this site supplied the solar panels, he did big buy of Schuco Panels when Schuco pulled out of the market. There are a lot of offspec Chinese sourced panels for sale for cheap these days but I prefer taking my chances on panels that were built by a known companies and were built to German specs . Generally panels either work out of the box or don't and if there are manufacturing defects it takes years for them to appear and by then good luck with a warranty. They are nicely built panels and the ones I got were A spec. Most panel companies test each panel and grade them by output, they usually then have 3 or 4 model numbers which are identical except for output. The panels I got from Tom were the highest efficiency, 245 watts as opposed to 215 watt for the lowest efficiency meaning more output in less space. Many of the closeout panels on the market tend to be the lower efficiency models( fine if you have the roof space although the mounting costs go up).
I haven't added up the total cost, its close to 4.5 K with about $500 extra for the rework on the electrical system. I have already eaten up the NH rebate but will get a fed rebate of 30%. At $2.5 a watt compared to an lot of pro installs in the $4 to 5 per watt range (some pros say they are in the 3.75 range these days) , there are savings to DIY as long as you are willing to learn and follow NEC 2011. Ideally with some help and cooler weather I could have installed itallin a weekend. As is was I did everything solo including pulling the panels up on the roof.
For general reference on how much it generates, I have a pole mounted PV system not shown with roughly the same capacity as the new array. It will put out somewhat more yearly output as its adjustable tilt plus runs cooler but the combination of the 4 older panels on the house and the pole mount covers all my electrical use and I am running a 750 KW surplus after about 15 months of operation. If I installed 3 more panels on the new system and took down the wall mounted panels, I would have all more power needs covered including a fridge and freezer plus an electric range assuming I installed a Heat pump hot water heater to back up my wood system for hot water in the winter. As I mentioned previously the new install will cover heating in shoulder seasons to cut back on wood boiler use and hassle plus cover the house when I am not home.
One day when the 660 watt system's inverter dies, there really aren't any good options to replace it as the system voltage doesn't line up with modern grid inverters, I ran all the panel wires down to a junction box in the basement and did the series and paralleling in the box so I could add a charge controller and install some batteries and have battery backup but I am waiting to see what newer battery technologies appear.
Now on to the next project once I catch up with all the deferred projects.
