elkimmeg said:A common practice is to stagger the heights. Meaning the liner and cap should extend 9" higher than the adjacent flue
How does staggering the heights of a multi-flue chimney mix with the 2-3-10 rule? Seems like if you are staggering, then the lower flue is in violation?
Metal said:How does staggering the heights of a multi-flue chimney mix with the 2-3-10 rule? Seems like if you are staggering, then the lower flue is in violation?
The 2/3/10 rule is not a recommended height, it is the minimum height, so just make sure the lower of the two flues passes the 2-3-10 rule and then the higher one must pass.
bcnu said:I understand the 2 and the 10, so what is the 3 of the 2-3-10 rule. I did a search on this rule and still didn't quite understand the explanation.
