Having a problem finding the correct way to put a hearth pad together. I'm trying to keep it simple as possible and still have a pad that won't crack. I have found a lot of opinions, ideas, and methods, stack-ups etc, but none on the way I want to do it. The pad is going on to 3/4 sheathing with 16" OC joists and i want to cover with porcelain tile.
I want to make it 48x48. I have two 5/8" Micore 300 pads of this size, so I have my R factor.
How do I stack it up to reduce the risk of cracking tiles? I worry about the Micore compressing under the stove.
From the info I've found, I think I need to go with Micore and 1/2 Durock screwed to floor, then Micore and 1/2 Durock screwed to the 1st layer of Durock, then modified thin set and tile.
The only Durock I can get is 1/2" 3x5'.
And it stands to reason that leaving the pedestal on the stove (rather than installing the legs) will reduce the risk of cracking tiles.
Any input is greatly appreciated.
