Here are a few photos.At that age, maybe not much more than scrap steel value
Yeah that's probably about it though...would be worth that much to me to leave it installed as a heater in its existing shop...with some clearance/install tweaks as needed...some insulation in the building would make the furnace a lot more effective too...so I would say $250-350 is fair.
Do you still have owners manual and stove I would like to buy . 1 502 553 4144 Thanks DJI bought a house a couple of years ago with a wood furnace in the garage. I have used it once and probably won't use it again. What would it be worth?
Do you have manual ? My stove is a boiler . I would like to know how may btu s are they rated at ? I have no info on these , but have been using it for over 20 yrs . Any help would be appreciatedjadams92 I have the same stove and heat my home with it. Have a question of you and started an conversation....hope you see this....Thanks Mike
To be honest, I would walk past the opportunity. I have not seen good feedback on these. I have really not seen anything convincing about the outdoor ducted to indoor approach being anywhere near successful, except for absolutely gobbling up wood.Hello all,
Looks like Im a little late to this thread but have just a quick question on this furnace. I have an opportunity to buy a similar model for a good price but I’m just trying to do my research first. From my understanding this particular unit can actually be installed outside The home and then the air ducting is ran into the home and Into the existing duct work? Our old house has a chimney but it’s no good anymore and I don’t have the cash for a wood boiler just yet Thinking this might be a nice unit for the next three to four years while I save up for something newer.
I’d try to find a used woodstove / chimney package for sale locally, and run it out the wall if through the roof isn’t possible. It’d be much less of a rabbit hole to go down.
The problem is that most of the wood you put into a furnace of that design goes out of the chimney. They’re not good at collecting the heat they produce. They overcome this by having big fire boxes and forced combustion, and an insatiable hunger for wood.Would it work any better if a guy went through the work of burying the forced air lines going to the house? Try and keep them insulated and out of the cold?
