1980 VC resolute question
Hugh720
1
60010
Hello, I
I just bought an used Resolute. The tag says it was safety tested 9/25/1980. Serial number 054445.
Does anybody know where I can find the manuals for this model?
I need to replace all the gaskets and clean out the secondary burn chamber as it appears to be half full of ash.
I am curious as to structure inside the chambers so that I can best remove all the ash.
A manual would hopefully show a blowup of the structure and parts?. I also would like to know if I need to replace any or all of the exterior gasket material that I saw on Utube used when VC builds them.
Stove appears to me to be in great shape except for minor rust spots on exterior. I'm assuming a wire brush is best for this issue.
Thanks
Hugh
Hello, I
Thanks
Hugh
Hugh, there is a link for the manuals in one of the sticky threads at the top of this forum.
I just cleaned and painted an old vigilant, a wire brush drill attachment works very well on the rust
Hello, I
Thanks
Hugh
I have a 1988 Resolute Acclaim that I am still using, great stove! I lost my manual and printed off a new one from VC website
under owner manuals. I have only replaced the rope gaskets so I would be curious how the cleaning of the secondary burn
chamber goes.
The 1988's Acclaim's construction is completely different from the original Resolute's construction. The cleaning process is different. Are you sure you don't have the Resolute III? That was made up through mid 1988. Is there a refractory assembly in your stove or a cast iron back in the firebox?
If the picture in his avatar is it, it's not III, there's no two hinged door arrangement.
You are correct, it is different, mine is just cast iron
Then the stove is a Resolute, not an Acclaim.
