I have read many times where people recommend covering piles with plastic with an opening at the top and bottom to create a solar heating effect. The only controled study that I've read for this showed no effect- probably because there was less area for moisture to escape. The increased heat was offset by reduced overall air movement, trapping moisture in the pile.
I have a strong interest in novel burner technology (like coffee-can gasifiers, etc that cost nothing and stretch fuel amazingly in impoverished places). Simple fact is that hot air rises (derrrr). What if a simple "plastic solar wood kiln" were amplified by the addition of a black sheet metal preheat box? This would be connected to the bottom tarp opening and act to more efficiently collect solar heat, and to increase convective flow through the "chamber".
How the wood is stacked to provide airflow across all portions would need to be thought out, as would wood access for reloading. I anticipate that small loads could be dried fairly quickly, and then just reload the suckah. This idea sort of springs from another idea that I had for a guy living in high desert to dry wood chips that he was going to use for fuel by putting them between 2 pieces of corrugated metal at an angle, and painting the top one black- the whole apparatus would heat up, and natural convection would pull air through. We also had an idea on reloading, and semi-automation.
Has anyone had any experience with trying to boost heat or natural convection in makeshift solar wood kilns?
Thanks
Thanks
