Moosestache said:My friend has been using his wood gun for 2 full heating systems now. He is very happy with it overall. I think his words were "working as advertised". He does not have any water storage and he didn't see any real need for it. In actual use, in the cold months, he filled it three times a day and never had any issues with it going out or anything. The only issues he mentioned, and this was also mentioned by the people at wood gun, was that you should expect to replace some of the refractory bricks regularly. It is an easy easy thing to do, but I would expect to do this every couple of years, maybe $200ish each time, I'm sort of guessing but close. I ordered one of the carbon steel units. I saved a substantial amount by going with the carbon unit, and my general feeling is i should get at least 15 years out of it, and I would bet in 15 years the technology will be much better than what we currently have and I will want to change anyway. With oil as high as it looks like it will be, I figure no more than a 3 year payback... 1300 gallons of oil even at 3$ is $3900 I can get the wood for $1000 ....should be 3 years easy.
Dry steam said:I have a wood gun E-250 SS chamber and so far I'm very happy with it. My version is for steam heat and one of the few if not only wood fired boiler for that application. I have gotten relight times of up to seven hours using decent but not excellent wood. Maintanence is simple, once a week clean it, about a half hours work; then fill it, burn it. AHS seems to be very easy to work with and any problems were discussed up front. Those problems being the replaceable refractories, gasket issues on doors and wearing of ceramic door linings. These were acceptable to me as regular maintenance items. So far I am very pleased and would recommend this boiler to any one.
Now I'm not going to trash their competition, I'm sure they all make a comparable unit, however I have been around the forum and other gasification units seem to be very maintenance driven from opening this door to then cracking this door to relighting every time etc.... With the wood gun I don't have to do this. I light it and walk away until I refill the box. I have had the same fire going since November! just add wood and clean.
One note the flue needs to be stainless steel... preferebly 22 gauge or thicker there is an amount of moisture from this stove, but I attribute it too my not so perfect wood supply. (seasoned) I have a class a all fuel chimney prior to this boiler install.
This boiler has only been in service since OCT 08. Installed by me, including the steam piping.
Der Fiur Meister said:Dry steam said:I have a wood gun E-250 SS chamber and so far I'm very happy with it. My version is for steam heat and one of the few if not only wood fired boiler for that application. I have gotten relight times of up to seven hours using decent but not excellent wood. Maintanence is simple, once a week clean it, about a half hours work; then fill it, burn it. AHS seems to be very easy to work with and any problems were discussed up front. Those problems being the replaceable refractories, gasket issues on doors and wearing of ceramic door linings. These were acceptable to me as regular maintenance items. So far I am very pleased and would recommend this boiler to any one.
Muncybob, Dry Steam and Fred61 thank you all for your opinions. Your experiences are helpful. It seems there are a lot of variables to consider.
I have a 6"X6" masonry tile flue approx. 23' tall. Installed new in 1993. I check it every year. It's in great shape. Have you heard of any problems with the Wood Gun or other gasification boilers using a tile flue?
Eric Johnson said:I think it's great that somebody actually makes a wood-fired steamer for residential use. Steam heat is a wonderful thing, and there are plenty of houses around with steam power plants. Converting to hot water is a major expense and fraught with potential problems.
