- Apr 5, 2006
- 2
I recently bought a house with a wood stove. I then learned behind the wall where the pipe went was an old fireplace that was covered up and the pipe was put up the chimney. The stove was kind of old so i removed it in hopes of cutting a hole into the stone facing the put up to cover the old fireplace and sliding the insert in and attaching the old stove pipe some how. I bought a used old wood fire insert. The part i don't understand is the insert has 5 holes about 3 inch in diameter in the top instead of one out let. is it still possible to let that vent straight up the chimney and remove the old stove pipe in there now. If that isn't enough detail i will try and explain anything else i can. There is no name on the insert. also the old fire place is very large is it possible just to put the insert on bricks and not have any support on the sides or top.
thanks
eric croker
thanks
eric croker
