I have tried to search the forums, but I am so new, that I really don't even understand a lot of the basics and lingo. I have a Hampton HI1300 coming and trying to decide on all the details of install. Depending on who I talk to, I get so much conflicting information. I want to know enough to at least ask the right questions.
I have a white brick/ rock, internal fireplace downstairs in the middle of my living room with a heatilator. The chimney passes thru the bedroom upstairs, but I don't see it. It is fully enclosed the wall. the staircase actually passes up the back of the fireplace, which is enclosed in drywall, also.
What I have been told is they will cut out the three tubes in the heatilator part so the pipe will pass. They told me they would use a stainless steel pipe.
That is really it. I have read tons on .........
flex vs rigid
single, double, triple pipe
solid pack vs air cooled
class A
block off pipe
put basket at top, fill with insulation and seal with silicone
supraflu???
replace screws with stainless nuts, bolts and screws
My main concern is that I will get a installer in here, will do a minimal job cuz I don't know anything about any of this, and I will have problems or my insert will not perform in the manner that it is capable of performing.
Thanks for all you help!
flex vs rigid
class A
block off pipe
supraflu???
