Carl said:Only if you need or want it.
what wood you suggest.....englander?Harley said:I'm a little partail to them right now - again - depending on the condition - sounds like a good price. If this would be the one to go downstairs, after the work on the existing fireplace - I'm not really sure that it would be the right stove to have in there.
iceman said:what wood you suggest.....englander?
Harley said:iceman said:what wood you suggest.....englander?
Tough to say for certain - it depends on the layout of the area, and how you use that room. If the 2'nd stove is to give a some quick, extra heat on really cold days, and that room is not an area where you spend a lot of time - I would think a cast or steel stove might be your best bet. On the other hand, if the downstairs location is more of a finished room where you spend a lot of time, but the heat from the Summit doesn't reach there, a soapstone stove could be a good fit. They really need to be running 24/7 to be effective.
BeGreen said:The Heritage would be sweet if you don't mind starting it up a couple hours before you are using the space. For quicker heat, it sounds like a medium sized low cost stove like an Englander 13NC or equivalent cast iron stove would do the job.
