Wood consumption survey
Vtgent49
100
Central VT
Can we try a survey related to wood consumption? Just asking Boiler users, who are 75+% wood users, and who have a full season (or close) of data.
Responses should include:
Boiler type: Indoor or Outdoor, Gassification or Not
Building: Sq feet and relative insulation quality
Wood quality: Hard or soft, etc.
Quanity of F Fuel used for back-up:
DHW included: Yes or no
I ask because I hear fairly wild estimates of savings by gassifiers, then hear of rather large quantities of wood being consumed, then from others who seem extremly successful. I'll start with my responses in the next post.
Hi,
Wood/oil boiler, indoor, 23 years old, non gassifier, no storage, baseboard
2300 Sq Feet, medium quality insulation, ca. 1985
Central Vermont
Hardwood, A+ quality and dry
DHW included all winter, then had gas b/u
4 Cords, 200 gals oil, 160 gals LP
Notes: LP DHW is now gone, solar on the way, 1/2 of oil used when on vacation
This thread is less than two weeks old and has much the same data.
My own update:
Boiler type: Indoor / Gasification (EKO 25)
Building: 3500 square feet, well insulated, lots of glass
Wood quality: Variable, mostly hard but lots of small and some punky junk.
Quantity of Fuel used for back-up: < 5 gallons
DHW included: Yes - hot tub also
Wood consumption, October 15 to present: about 3 3/4 cords.
My brother next door built a gasifier and heats exclusively with it. He's around 3.5 cords, slightly smaller and better insulated house.
My own update:
nofossil, to me that is nothing but amazing. I don't have a full season in so I am not going to give my stats but I do know that I am over double that in 2 months. I can't even imagine using that amount of wood. Wishing I had your stats
From what I've read, nofossil sets the standard. But 4 cords has worked for me for many years and in a few different houses, although 50% smaller than his. Frankly, I love cutting wood, but 4 cords is about the limit of my attention span. I am concerned about hyped savings not working out. Wood heat has been around a long time.
Boiler type: Indoor / Gasification (Econoburn EBW-200)
Building: 5200 square feet, 28 year old home insulated, lots of glass, 18' vaulted ceilings.
Wood quality: Good Hardwood
Quantity of Fuel used for back-up: 0, zilch, not-a and not going to use any!
DHW included: Yes - 40 gallon indirect fired.
Wood consumption, October to present: 9 cord.
Found out my underground lines (100') has been compromised with outside ground water. Loosing lots of BTU's to ground.
Replaces approximately 1500 gallons of fuel oil.
My old outdoor wood boiler used 30+ cords last winter.
I was a bit skeptical about wood consumption (and everything else). Based on previous experience in other houses in Vermont, I had expected to burn 6-7 cords. In my first two seasons, I burned 3.2 and 4.5 cords, and I'm on track to burn just over 4 cords this year. I'm a believer now.
My brother next door has heated with wood for years, first with a conventional indoor boiler, and with a gasification boiler for the last two seasons. He saw a 40% reduction in wood usage with the gasification boiler.
I suspect that there are many ways to burn more wood for the amount of usable heat delivered. I've spent a bit of time studying and optimizing the performance of my system. A couple of things that I think are important in achieving the performance that I've seen:
1) Dry wood. Not necessarily bone dry, but well seasoned at least.
2) A burn pattern of many short, hot fires - no idling. Storage helps a lot, but is not absolutely necessary.
Boiler type: Outdoor, Gasification: Greenwood 100
Building: 1100 Sq feet log cabin with relatively low insulation quality. 6 inch logs and old windows.
Wood quality: Hard and Soft. Dry.
Quantity of F Fuel used for back-up: None
DHW included: Yes.
Probably have burned 6 cords since November - maybe 7.
Pete
3500 sq ft 2 story farm house. 100+ years well insulated but no windbreak and in north central indiana that SUCKS. Heating dhw also for 6 showers per day and Lord knows how many cloths washing cycles. Furnace for upstairs and furnace for downstairs. Woodmaster 4400. Used 12 cords of wood, mostly pine, cottonwood, basswood and maple.
Hey Bill,
Those are very impressive stats! Whatever you're doing you're doing it right! Have you considered a career as a wood boiler control consultant? Vermont has long cold winters yet you manage to heat a large home plus all your hot water needs? Truly amazing.. Your brother doesn't do too bad either.. Have you tweaked his system at all? There is no doubt you set the standard here..
Keep up the good work,
Ray
Boiler type: indoor combination wood/oil non gassifier: Benjamin CC-500
Building: 2800 Sq feet colonial with good insulation quality. built 1998
Quantity of Fuel used for back-up: about 150 gals oil
DHW included: Yes.
5.5 cords since Oct.
What type of gasifier did your brother build? From scratch, purchased plans? I am intrigued by the seton as an option to build.
Thanks,
Craig
My own update:
Boiler type:CB 6048
Building: 5,000 SF 200 year old farmhouse. insulation varies thru the house
Wood quality: Hard and Soft. Dry and green
DHW included: Yes, 100 gallons
8 or 9 cords since Oct.
Seton 100 Indoor, located out in room off garage. 1st season. No splitting!
heating 2900sf house, 800 sf garage and DHW. And boiler room.
70 degrees constant in house and 65 in garage constant. Boiler room 200sf 80 deg's!
I will burn about 10 cord plus this year. NO OIL!
I have heat losses underground also that needs to be addressed. Pump volume? maybe.
Last year:
Jenson indoor boiler, same location.
heating 1100 sf house, 800 sf garage, DHW and boiler room.
This part of the house is not well insulated.
Cut, split, stacked and burned 12 cord. NO OIL.
So; I've almost doubled the size of my house and burned less wood. And I keep it warmer. And no splitting and stacking. And I'm selling my wood splitter.
But; It should be noted that if your wood boiler is in your basement the residual heat gain is tremendous. It can be like having a wood stove in your basement AND still enough hot water to circulate through the house and heat DHW.
If my boiler was in my basement, my consumption might be half. It gives off that much heat.
