13 nc has arrived!
Rebelduckman
1,105
Pulaski, Mississippi
Went and picked her up yesterday. Managed to get the side heat shields and legs on. I went with the nickel hardware. That pedestal was a real pain getting off. Can't wait to finish the hearth and burn it in. Got a few days cool weather coming next week so I may get to fire it up! [Hearth.com] 13 nc has arrived!
Looking at those tiny legs, no surprise it needs a R2.0 hearth. I am thinking that a long leg kit option that reduces the hearth requirement would be a good idea.
Ten foot tall legs wouldn't reduce the hearth requirement. Stove has only been tested with the six inch legs.
Reactions: PapaDave
Does that mean it is out of the question to test the stove with taller legs to determine what hearth is required then? :rolleyes:
Yep. Who is gonna foot twenty grand or so for the testing?
Would that be the price for just testing the difference in hearth requirements or is that the price for the full stove approval testing? And why not have Englander sell the legs for $150 extra or so maybe after shipping back the short ones. Then people have the choice between buying/building an extensive hearth or just slapping on some taller legs. Btw. Woodstock offers an optional rear-heatshield for their stoves (at least the Keystone) with reduced clearances. My idea does not seem so out of the world.
Gonna be my first tile job. Any certain kind of thinset i need? Can I cut the tiles with a grinder?Tia
Give ESW a call and talk about it with them.
Reactions: PapaDave
when one submits a unit for testing it has to be tested in any "evolution" of the design, and each set of tests cost upwards of 10 grand (passing or not) in order to have the stove tested and given a lesser R value with the longer legs it would have to be tested for this to determine the reduction (if any) for the longer set. as far as the woodstock example above this was done when they were having the stove certified just as our was to secure listed clearnces on the heat shield for our models such as the 13-nc the Op has.
FWIW the 30-nc was tested with 6 inchers as well and sold now with the 9 inchers as a standard offering, however the R factor was not changed when we went to the stock 9 inchers as a retest requirement would have been necessary to do it. now , had the stove been listed with the 9 inchers we would not be able to offer the 6 inchers as an option without retesting as it would have made for a closer clearnce below the stove where the other way around crwates a larger space.
Reactions: PapaDave
Thanks, that was enlightining. As far as I can see you are moving away from stoves that require hearths with large r-values anyway, so that problem will become a non-issue at some point.
yeah, we're making a concerted effort to design for low R factor if not ember protection with our newer designs
Reactions: Grisu
That's a good trend. It's a pain to feed a stove that is so low. Isn't the Madison ember protection only?
yeah the Madison is Ember Protection only , i seriously doubt we will be fielding any more woodstoves with that high a R requirement in the future
The goal should be to require NO R-value requirement in my opinion. This is so that when you install an englander on an existing hearth you do not need to worry about what may or may not have been used in the construction. Additionaly, it's easier for new installs. Surely this is the goal already.
Well....SOME of us actually preferred Mary Ann over Ginger. :)
I'll stick with the 6 inch legs thank you very much.
I'm getting there guys. I'm setting at at R 1.78. Got one more layer of durock to put down and I'll be at 2.17. I've got slate tile, should I seal it?
Reactions: stoveguy2esw
Is this Durock NexGen? If so, two layers = R 0.78. At R=.039 per 1/2" it would take at least five layers of Durock NexGen to get close to R=2.0. That's why a layer of micore is suggested for the bottom layer.
No micore to be found down here anywhere.
There's 3.5" durock piers under there spaced every 6 inches. I've just put the final layer on to give me 2.17.
you know 1 inch of ventilated air space = "R-1.43" if the blocked area is designed to allow circulation (not the traditional "joists" but an open area with stringers arranged to take the load without making compartments one could use a durable non combustible subfloor with air space and vents to allow circulation of air and not have to stack durarock in multiple layers
Reactions: yooperdave
If that is natural slate it would be a good idea to seal it before you grout. The sealer will act as a grout releaser making the clean up easier. A second coat of sealer when the grout dries will finish things off. Check the sealer for temperature limits to avoid prolonged off gassing. That stuff can smell pretty nasty. Looks great so far!
Reactions: firefighterjake
This is my first rodeo. I've got a piece of cedar I'm gonna trim with in the front. Would you install that before grouting?
