hey guys..my glass is very dirty and i've only been burrning a week..I tried to clean it with windex but it wont come off...any ideas?
Fire Bug said:Rutland makes a cleaner called Rutland White Off. It works excellent on ceramic glass front on stoves, inserts, fireplaces. It also is highly recomended for ceramic cooktops on kitchen cook stoves.
It cost about five or six dollars a bottle which will probably last you till you die.
Never, ever, ever, use an amonia based product on ceramic glass, it will, as mentioned earlier, etch the glass permanently. Also, never, use any type of abrasive cleanser, it will scratch the glass.
I do like the wet paper towel/ash paste method. Sounds like the Rutland White Off.
John
PA. Woodsman said:I've had great luck with Rutland Hearth & Glass conditioner; it cleans off the mess and leaves a silicone layer on the glass to make the next cleaning easier.
Fire Bug said:PA. Woodsman said:I've had great luck with Rutland Hearth & Glass conditioner; it cleans off the mess and leaves a silicone layer on the glass to make the next cleaning easier.
Is there a Rutland glass cleaner and conditioner or is there only the Rutland glass cleaner?
John
mtnxtreme said:Regular "Easy Off" foam oven cleaner takes it right off, just wipe with a paper towel, it's cheap and can be gotten at any grocery store.
Fire Bug said:mtnxtreme said:Regular "Easy Off" foam oven cleaner takes it right off, just wipe with a paper towel, it's cheap and can be gotten at any grocery store.
I am not to sure I would want to use any type of oven cleaner on any type of ceramic glasss without having some type of adverse results.
Be carefull of this. I would imagine oven cleaner is almost like some form of acid and will permantly damage the ceramic glass sooner or later.
