Hello
Well I sold the Pelpro and Purchased a Quadrafire CB1200 so the Lux DMH110 for 24v or millivolt systems that I got for the Pelpro does not look like it will work for the Quad. Instructions say 12v AC ??
So does anyone know what T-Stat can be used for the Quad besides the OEM one?
Does it need a high Swing Setting like around 2 Deg F??
I would like an all manual T-Stat since the stove will be in the shed and I can turn the T-Stat on with a switch in the house.
Quadrafire CB1200 manual page 22
1. A 12 volt AC thermostat is required to operate this pellet
appliance. You may use the included wall mount thermostat
or purchase an optional programmable thermostat
or remote control. It is equipped with an adjustable
heat anticipator. The current rating is .05 amps. The
anticipator needs to be adjusted to the lowest setting
available
Pics will come if I get this thing working!
The low limit switch is stuck closed so the convection fan keeps running.
Also the stove was in damp storage with pellets in the hopper that disolved and made one tough AUGER JAM!!
Anyone know a good way to get them out so I can remove the Auger??
available
