12 Ton Splitter, CL ad seems like it might be a good buy
HDRock
2,239
Grand Blanc, Mi
Seems like it might be a good buy, for what it is, what do ya think
Looks like it is this model ,Earthquake 12-Ton Gas Quick-Split Horizontal Log Splitter w/ Briggs & Stratton Engine
They might take $450
ADD -Log Splitter - $499
12 Ton, Briggs Motor, Runs great, Only used a few times.
Awfully light duty but I guess it depends on what you intend to use it for. 12 ton machine, I think I'd seriously consider continuing to split by hand.
;lol I use a HF-7 Ton Elec, Splitter, very little splitting done by hand.
Then keep the 7 ton and save your beans for a 20 ton+ machine. Buddy of mine just picked up a 2 yo like-new Huskee 22 ton for under $700.
Ya, I been lookin, lookin,lookin for a used Huskee
I did find one
22 ton huskey log splitter built in 2010 - $900 this is a very well maintained machine changed fluids every year
22 ton huskey made into a 24ton machine ,highrate flow hose ,speco. valve looks great runs the same first pull starts right up no disappointments here.
For that $$$ I would get new
I had one of those, had a 6.5 hp chink built Honda clone motor instead of the Briggs though.
Sold it yesterday for $400. I beefed mine up a bit. Got ride of the tiny pusher and wedge and put normal sized ones on. Worked well though it's pretty slow. Cycle time is about 30 seconds.
As far as "only" 12 tons, it split everything I stuck on it. I ran about 15-20 cords threw it this past summer. It'd be a great unit for someone splitting just a few cords a year. The slowish cycle wouldn't be too bad and being it's fairly light and small it's easy to more around and fit in the corner of the shed.
I just bought similar 12 ton unit for $300 So far it is working great. Because of my location 99% of my wood is pine that this things takes care of without a problem. I managed to score some fairly large elm rounds off of craigslist the other day and put this little spliter to work. To my surprise it easily handled these rounds that are way over the recommended capacity.
I would love to have a 20 ton or larger spliter but this thing works well.
  • 12 Ton Splitter, CL ad seems like it might be a good buy
Reactions: raybonz and n6crv
Was that the first cycle? That ram looks like it's dancing back and forth a bit there like there's air in the system. Cycle time looks great tho. The chirping noise you hear as the ram contacts the wood is most likely the pressure relief valve.
No, I had spilt the other stuff on the ground before I put that big round on there.
Is that chirping noise bad?
Just means the system has reached it's max pressure. It''s not a bad thing if it's not there constantly.
