I'm getting drops of liquid creosote off my spark arrestor and its adhering to the roof jack and unto the roof shingles. Not only is it unsightly, but I'm very concerned with fire danger. Never seen anything like this, although I've not had any experience with wood stoves of this type that have a thermostat and two ways you can burn the wood, horizontal or vertical.
A little history.
We had been given a Vermont Castings (1984) Resolute III, and finally got it hooked up with a Simpsom three wall kit (9 ' of three wall + two 45* single and bottom sections which equal about 8' for 17' altogether) through the attic to the roof. Fired it up first time Dec 07. Read and re-read the instructions that I downloaded on the model from the web site. Have heated up the stove to 500-600* before putting four more pieces of wood into the stove, (6 total) for night burn in the horizontal long burn mode, and then have kept a close eye on it, as its been a long time since I've had a stove like this and not an open hearth fireplace.
On the 15th, I went up on the roof and checked it out, and cleaned the pipe and and actually dismantled the interior stove pipe to see how much creosote build up there was on the lower half as I was forced to have to use the two 45* for offsetting the ceiling joist. It was more than I expected, for only having been burning 24/7 for a week, but nothing close to being 'choked'. Maybe a little less than an 1/8 of an inch. At that time I didn't really pay any attention to any 'tar' on the roof jack, but noticed that the spark arrestor and the top inch of the flue had quite a bit of caked creosote on it, and some standing tarry liquid. Hmm I said, weather or some wet wood. Cleaned everything. On Christmas eve, went up again and that's when I started noticing the drips on the roof jack that had condensated from the spark arrestor, and some on the exterior of flue. Hmm, cleaned the flue again, this time with it all together, pulling through an older 6" brush from the bottom (as the diameter seems to be a little tighter on the older enamel single wall pipe) and using another, new, 6" brush on the fiberglass pole to really clean the top Simpsom section. About the same amount of creosote, but boy the roof jack is getting covered, and now one of the roof shingles near the bottom where it's draining to, is looking 'wet'. Some of the drops have dried in place. But there is a 'tar' rim at the bottom edge of the roof jack from I guess more liquid creosote.
After company gone, started going up on roof and checking the liquid tar. During the day I kept it on standard vertical, flue open short burn, and had no staining, standing liquid creosote. Ran the long burn that night. Kept an eye on it, rising in the night three times to see the temp on lid was 400*, hotter than the 300* that the day burn setting I had it at. (hey its Arizona ;-) Next morning went up on roof, and had standing tar. Cleaned it up with a paper towel. Last night, instead of putting in 6 pieces of split or round oak, used four, and set thermostat to around 300-400*. This morning had standing liquid creosote. Sooo... the temp was not as low as its had been, last night around 34*, so all I can think as it being cooler at night it caused the creosote to condense. Have used almost 100% seasoned oak, but we had quite a rain several weeks ago, just before we put the stove on line, and the wood got wet. Since have covered it and have had no rain since. (hey it is Arizona ya know ;-) and brought some of it under the front porch. Love the stove... really works well. I had dismantled the two sides before installing it and tilted it on its side to get the ash out of the back chamber, there was a mess of it, not much in the left side. Resealed the two sides with 2000* Rutland stove & gasket cement.
Ok... any ideas??
Could it be seasoned, but not seasoned enough oak? Perhaps it got wet from the rain and this is the culprit. I have no other wood to try but some pecan. Perhaps that could prove the wood, or not. Whatca dink?
BTW... I found this wonderful web site this morning while doing a search on for creosote.
thanks for any help,,, p.
A little history.
Ok... any ideas??
