I borrowed a squirrel blower from a pal, jammed it under the stove w/ a coal rake and a split of ash and I can say you're right -- a fan is going to make a big difference in the heat output of my stove.
But I'm as tight as... as tight as... well, as tight as the bark on a tree and I just don't feel good about plunking down 250 clams for a Lopi specific blower. A Regency generic is going to run $110 clams or so. Some of the long gas/fireplace fans look like they'd work with a bit of modification. I've checked surplus center and electricmotorwarehouse and the I know for some of you the hassle's not worth the savings, but others of you would get peace and lasting satisfaction knowing you helped another tightwad.
I was all excited about at surpluscenter double squirrel blower for $18.00 till I realized the housing was plastic. It might not even matter since my Lopi is mobile home rated and you can touch the bottom of the stove without burning your hand. But I'm not taking my chances.
Anyway, I'd just like to hear some of the expertise from fellow tightwads. How many CFM's does the Lopi (and most Avalons) generate? Are they quiet? Anybody found a good alternative? Can you get specific about what you found?
