Hi All,
I had a successful experiment over the weekend that I thought I would share. My castile insert was installed last year and the dealer never even mentioned the possibility of an OAK. After reading way too many threads on this forum about how OAKs eliminate stove-induced drafts, I decided I needed to have one. Last year, I could feel a constant flow of cold air coming from the basement stairs and front door heading straight for the stove in the living room.
Quad recommends that you bore a 2 inch hole through your fireplace wall for the OAK to reach the outside. This seemed rather permanent to me (and difficult), so instead I just ran a 3 inch aluminum dryer duct up through the damper plate and made the damper as air tight as possible by tightly packing insulation around all the seams (see photo). The duct only goes up about a foot past the damper.
I connected the dryer vent to the OAK hole behind the ash pan using foil tape. I had to manipulate the 3 inch vent a bit to fit nicely with the 2 inch hole, keeping everything sealed with the foil tape.
I then sealed the entire ash pan compartment, again with foil tape (see photo), because Quadrafire stupidly designed the stove to draw air both from the outside and from inside the house through the gaps around the ash pan. I figured that unless I blocked off those gaps, the stove would probably pull most of its air from the room rather than through leaks in the chimney. Losing access to the ash pan wasn't a big deal because when cleaning I vacuum the burn pot before pulling the rod that opens the bottom of the burn pot. And if I ever want to vacuum the ash pan, I can just stick my vacuum down through the burn pot.
When I turned the stove on, I was expecting to see a weak, lazy, sooty flame as my combustion blower struggled to draw air from my sealed chimney (the top of the chimney is sealed off). Instead, the burn was just as good as when the stove was using inside air. I guess my chimney isn't very air-tight. Also, I've already noticed that the drafts are gone, and the rooms furthest from the stove (i.e., the bedrooms) are noticeably warmer. I actually turned down my thermostat by a degree or two because the high temp was no longer needed to keep the further rooms warm.
So, all in all, it was a great success, all for a $10 dryer vent and some foil tape! And I would recommend to any Quad owner with an OAK to consider sealing off the ash pan like I did.
![$10 Airtight OAK for Quad Insert - Successful Experiment $10 Airtight OAK for Quad Insert - Successful Experiment](https://www.hearth.com/talk/data/attachments/166/166864-34a586562ad6f3ab766c44dfd3da9f62.jpg)
![$10 Airtight OAK for Quad Insert - Successful Experiment $10 Airtight OAK for Quad Insert - Successful Experiment](https://www.hearth.com/talk/data/attachments/166/166863-de3b4aef865eeb43183372060bdb6514.jpg)
