Hi.
I've been reading posts on the forum about safe stove clearance, and have a question.
Current stove is NOT installed with safe clearance. If I'm understanding what I've read so far, I can potentially get less than the generic 36" clearance by having a 1" ventilated space. (House is 2nd home 4 hrs away so I don't have access to the stove manual right now but will look up specs when I can).
Current hearth wall is stone veneer on raised (false) cement board wall as pictured. There's an enclosed hollow space between the hearth wall and the actual drywall.
This is an enclosed air space, but *I think* if I cut vents in the top and bottom, it would become a ventilated space... am I understanding correctly?
Also, are clearance dimensions measured to the nearest flammable surface (drywall/studs) or to the nearest surface (stone veneer)?
Many thanks for your expertise!
(btw, I'm also aware I need to switch to a double wall pipe because of the wood mantle... )
![1" ventilated air space 1" ventilated air space](https://www.hearth.com/talk/data/attachments/297/297926-92188bdb94070b774c333292a892f7f7.jpg)
