Should fireplace inserts and hearth stoves have a metal sealing plate installed at the Damper area?
Here is the simple answer. It is almost impossible to correctly seal most insert panels to the fireplace front. A lot of air can get through them - this works both ways.....hurts the draft when stove is being used, and can leak cold air into the home when it is not in use.
Here are instructions for making such a plate for masonry fireplaces :
http://www.hearth.com/talk/threads/...ock-off-plate-for-a-masonry-fireplace.147679/
Now go back in time a few years when most inserts were not lined to the top. This made the lack of a plate even worse as soot from the chimney could easily fall down onto the insert and also even more draft from and to the home (because of no seal at the top)...
Then there is the issue of keeping as much heat in the home space as possible.... if the plate is properly installed, everything below it becomes part of the home space and the panels are purely decorative.
So, while it is possible that an full liner installation might be legal (with tight front panels and top seal), it is not the right way to do it. Im not being a stickler about this - the easiest thing I can relate it to is making furniture. Certainly a nail might do the job - but screws, glue and notches do the job better!
I dont think it is going to burn any houses down not to have a metal plate (with full reline) - cant see how it would, as the liner system is still 100% contained.
What about damper block off's on pre-fab fireplaces?
With a zero clearance you are not supposed to block off the circulating vents around the firebox front. But by blocking off the flue pipe you will achieve better results. With zero-clearances it can be tricky because you cant totally block off the fireplace in most cases. But, we maintain that is the best practice to block off the flue at the damper level. This will allow for the best draft through the insert and allows the use of panels to be optional, which may be needed with some ZC installs. It is often possible to use a metal trim ring for the block off plate as the damper in pre-fab fireplaces is usually small and round.
--summarized by Craig Issod
Begreen :
A block-off plate is particularly helpful with an insert or stove installed in fireplace on exterior walls with exterior chimneys. Without one, the flue liner (which should be insulated) and the stove will try to heat the mass of masonry that is exposed to the outdoors. This can result in a significant cooling of the stove and large heat loss. A block off plate keeps the heat where you want it. Here are links to installations with some great photos of how they did it:
www.hearth.com
www.hearth.com
www.hearth.com
www.hearth.com
Begreen :
Block-off plate construction
How to make a block-off plate A block-off plate is particularly helpful with inserts installed in fireplace on exterior walls with exterior chimneys. Without one, the flue liner (which should be insulated) and the stove will try to heat the...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
Poor man's block off plate installed
Finally got around to doing this once I had some vacation time. Prep Work 1. Got the materials, all from Home Depot: One package of Roxul Safe n' Sound, $42.00 One package containing three 5/8" wing nuts, $2.00 One 12" long piece of 5/8" threaded rod, $1.75. One 36" long piece...
Another Block off Plate install (with pics!)
Hi all, I wanted to show off my progress on my install – obviously I am not a pro but everything I did was learned from this site (so thanks!) - I hope to get the Fireview in place this week. I had some 22 gauge metal left over from my heart install so I used that to make the block off...
My DIY block off plate installation
I had another thread going about some questions and problems but since I have worked through it and finished I'd like to document the whole project FWIW. Starting from the top, what’s the reason? Well it seemed like my unit wasn’t throwing off as much heat as I expected. Of course this is...
