I’m of the understanding that a full chisel chain requires a different type of file and is sharpened differently than a other types of chains. Is this correct And how about a semi-chisle chain
No
No
and
No
Same round file. Different size chains require different size files though.
Yessir.Are a semi chisel chain, and a safety/low pro chain two different things ??
Yessir.
There be green label semi chisel chains, green label full chisel chains, green label low-profile semi chisel chain, green label low-profile full chisel chain, yellow labels of all the above as well.
FWIW: Most green-label chain is of the semi-chisel type. Stihl's RSC3 being the most common exception.
Low-pro doesn't necessary have anti-kickback stuff on it. Low-Pro is chain that is designed to run on smaller saws. It shares the same number of drive links per given length that regular 3/8" chain has but that's about it.Full chisel=square tooth, semi chisel round, low pro has extra rakers/depth stop, right ?????
We refer to the chain with all the "extra" junk on it as "gree-label" or "safety" chain.
Every day it becomes oh so much clearer!
Until your mind becomes a sea of part #'s, chain types, sharpening methods, operating technique, safety protocol, troubleshooting tricks, and doh! moments. Then you seek some poor unsuspecting internet community to unleash the whole mess upon.
That's exactly whats happening to mind, and-Until your mind becomes a sea of part #'s, chain types, sharpening methods, operating technique, safety protocol, troubleshooting tricks, and doh! moments.
Do I need a different guide for the 7/32 files
OK, ThanksYes. There is a different file guide for each pitch.
There are many types of Oregon file guides out there. The guide type dictates what files can be used in them. The kind I use is an Oregon Pro file guide. They are a bar mount file guide and they take any size file and will sharpen chain to any angle or offset. Here is what they look like:
I also have a mini electric grinder stone type with 5/32 and 7/32 stones for touching up a chain between file sharpening. They look like this, and there are 12V DC battery types and plug in 110V AC electric types:
Then there are the mini dedicated file guides that I do not use myself, that only take one file size. They look like this:
Then there is the Oregon raker file guide for using with a small flat file that looks like this:
