M&G DuraVent promotes Ventinox Rigid in the marketplace
webfish
Hearth.com LLC
Staff member
Oct 18, 2013
1,823
Minnesota
Vacaville, CA - M&G DuraVent making a push for Ventinox Rigid in the marketplace.
The Ventinox family has been expanded to offer rigid liner for use in existing or new masonry chimneys. The rigid stainless steel liner is used to mend and improve masonry chimney liners that vent Category solid, liquid or gas-fuel (coal, wood, oil, etc) fired appliances.
Ideal for use when the clay liner of an existing chimney is damaged. Ventinox Rigid is available in 5” up to 8” diameters in 304 type stainless steel.
  • Excellent resistance to corrosion.
  • 1/2” clearance to masonry chimney.
  • Double-lock seam.
  • Unique twist-lock system.
  • Improves the chimney’s draft.
  • Can be used as a substitute for the clay liner in a new masonry chimney.
  • UL 1777, ULC S635M & ULC S640M.
Controlled-combustion stoves are designed accordingly to highly efficient heat transfer and combustion technologies. Their rate of performance increases when they are installed with a chimney of proper diameter.
To learn more, please contact
M&G DuraVent
Tim Rothgeb, VP of Commerical and OEM Sales
Office: (800) 835-4429
[email protected]
