Hello all! First time poster, long time lurker.
Picked up a Jotul 602 B a few months back and I am finally getting around to planning the install. I was going to pay a contractor to do this install, but after spending many hours on this forum, I think I can handle it. Using duravent DVL in the house and triple wall through the attic and roof. I bought a kit for the support box roof flashing etc...
I am planning on using 22 gauge sheet metal spaced 1 inch off the wall and 1 inch from the floor. Hearth pad is still being worked out. Most likely 2 sheets of 1/2 inch durrock with 22 gauge sheet metal over the top plus this cast iron base we found.
The problem I am running into is the window near the corner where I am planning to install the stove. With the sheet metal I can reduce my clearances to at least 12 inch from the rear of the stove and 16 from the side with the pipe with go through the top of the stove. The wooden window sill is combustable and I am wondering what you think the safest placement of the stove would be in regards to the window. See pictures on placements. Also adding a picture of what I want my hearth pad and wall shielding to look like.
#1 The back corner of the stove is about 13 inches from the sill.
#2 I can get the side of the stove about 18 inches or a little more from the sill.
#3 Maybe can get back of the stove 14 inches from the sill.
My inspiration:
The two walls you see will have the spaced sheet metal. The wall with the window will have the shielding from the corner to the window.
something like this great drawing I just made![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Thanks in advance for any advice!
Sean
![Installing a Jotul 602 B need opinions on placement and clearances Installing a Jotul 602 B need opinions on placement and clearances](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FapZOmyr.jpg&hash=b1815f74425998c22e5acac8be0e3f0a)
![Installing a Jotul 602 B need opinions on placement and clearances Installing a Jotul 602 B need opinions on placement and clearances](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fzxuym71.jpg&hash=ea75ee763bf24b0d6507ab56812c8f40)
![Installing a Jotul 602 B need opinions on placement and clearances Installing a Jotul 602 B need opinions on placement and clearances](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FFMaB9ht.jpg&hash=d6f7a6e8bcd72b2906b0299d49eb8b3e)
My inspiration:
![Installing a Jotul 602 B need opinions on placement and clearances Installing a Jotul 602 B need opinions on placement and clearances](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F2pwXozt.jpg&hash=4b63f0b11f5374741f8364e54e9ff874)
![Installing a Jotul 602 B need opinions on placement and clearances Installing a Jotul 602 B need opinions on placement and clearances](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FtWSkImw.jpg%3F1&hash=4b19272d324f3c32815945c044a54e9e)
Sean
